Author Topic: NotReady State  (Read 2761 times)
Tang
NotReady State
We are using Nortel Meridian PABX Option 61 Release 25 and Genesys 6.1 ERS. When agents are put in Notready state from the Softphone calls are coming. Sometimes before filling up wrapup screen also, calls are coming in. What would be the exact reason. If anybody run into same problem or you have any solution kindly let me know.
joel
NotReady State
Take a look at the verification time parameter in the router reference guide. This might be the cause.
Marked as best answer by on September 02, 2024, 05:29:06 AM
dbm
NotReady State
  • Undo Best Answer
  • When are you sending your not ready. You need to send it whilst on the call. TO acheive this you need to set no_call_disconnect to 3
