Author Topic: Needed documentation  (Read 3284 times)
Offline LearnerGuy
« on: June 12, 2017, 02:33:20 PM »
Hey guys, hope you all are fine,
Does someone of you has this doc file?
[b]Agent Interaction SDK 7.6 Services API Reference.[/b]
Please share it if you have this file, I couldn't find it in the Genesys site.
Thanks!
Re: Needed documentation
« Reply #1 on: June 12, 2017, 02:53:44 PM »
This documentation is available on docs.genesys.com (of course you need to have an account)
« Reply #2 on: June 12, 2017, 03:12:31 PM »
https://docs.genesys.com/Special:Repository/76sdk_dev_platform.pdf?id=959d1007-5480-4ea3-92d5-85ca39a09405
Offline LearnerGuy
« Reply #3 on: June 12, 2017, 03:30:15 PM »
Thanks for your help guys,
I'm not sure if it's still available on the site since I was not able to find it, I think so it was removed, that's why I'm asking you for the doc if you have it on your own docs repository.
Thanks in advance.
« Reply #4 on: June 12, 2017, 04:50:16 PM »
The link I just posted opens the PDF directly or just search by the name, it will be the 3rd option on the results.
Offline LearnerGuy
« Reply #5 on: June 12, 2017, 04:55:46 PM »
Thanks for your reply,
The doc you shared me [b]is the developer guide[/b], what I need is the [b]Agent Interaction SDK 7.6 Services API Reference[/b] doc,
Could you please check if you have it?
Regards.
« Reply #6 on: June 13, 2017, 08:15:48 AM »
Little bit more effort please
https://docs.genesys.com/Interaction_SDK_API_References#Interaction_SDK_7.6_API_References
« Reply #7 on: June 13, 2017, 04:17:08 PM »
That goes for me too lol, I couldn't find it neither  ;D
Offline LearnerGuy
« Reply #8 on: June 13, 2017, 08:46:30 PM »
Thanks a lot for the document, it's exactly what I needed.
