Author Topic: Outbound Client  (Read 3004 times)
Roland
Outbound Client
Hi
We are going to setup the Outbound Solution.
Until the Outbound Client Interface is fully developed and
implemented in our CRM Solution we are looking for a interim
CTI Client. Does anybody have a Out of the Box Outbound Client
Interface which we could use for a short period of time ?
Requirements Outbound Client Application
Out of the Box Application (easy setup & configuration)
TServer 6.1 for Meridian & Outbound Contact Server 6.5.1 compliant
Preview / Progressive Dialing
Possibility to show all Dialing List Information in both modes (Preview & Progressive)
No need to install separate Database or WEB Server
Thank you very much !
Roland
Outbound Client
  • One of the best ways to do it would be to ask Genesys for outbound starter app. They have a sample app that does what you want.
    Roland
    Outbound Client
  • Thank you very much. Unfortunately I could not find any functions to reschedule calls or to set a treatment like "busy" or "no answer" in the Starter Apps.
