Author Topic: Chat Transcript EJS Issue  (Read 2881 times)
Offline Naveen Kancharla
« on: May 17, 2017, 07:24:57 AM »
Description:
Time stamp needs to get captured in Customer and Agent Chat window where as in the transcript, chat duration is getting updated.
After analysis we  found that the XSL code in Email Server Java required modification for getting timestamp captured in transcript. Can anyone help with this???
Sample:
00:00:04 MR.####: hi
00:00:06 #####: An agent will be attending your request in about0Minutes
00:00:51 #### : yes
Offline PeteHoyle
Re: Chat Transcript EJS Issue
« Reply #1 on: May 17, 2017, 08:01:10 AM »
Have a look here at how you can configure your transcript timestamp:
https://docs.genesys.com/Documentation/ES/latest/Admin/EmailSrv#transcrip103
You need ESJ 8.5.103.x or above
« Reply #2 on: May 17, 2017, 10:41:10 AM »
I have tried using below command on knowledge manager but still it not working.
<Genesys_Chat_Transcript><Timestamp>yyyy/MM/dd, hh:mm:ss aaa</Timestamp></Genesys_Chat_Transcript>
Offline PeteHoyle
« Reply #3 on: May 17, 2017, 10:56:57 AM »
What version of ESJ are you using?
« Reply #4 on: May 17, 2017, 11:35:23 AM »
ESJ version 8.5.101.106 . I think it will not work did you have any alternative solution for it.
« Reply #5 on: May 17, 2017, 11:53:15 AM »
Upgrade the ESJ as was mentioned before, you are using the old version.
