Author Topic: Data Access Platform SDK for Java  (Read 2400 times)
Offline WDev
« on: April 26, 2017, 02:26:37 PM »
Is it possible to access and update calling lists through Genesys SDK using dbServer? some suggest the use of the genesys Data Access Platform SDK, but I found that this Subcomponent is only available in the .NET genesys SDK 8.1, what are available options for the JAVA SDK.
Thanks for all the help!
Re: Data Access Platform SDK for Java
« Reply #1 on: April 26, 2017, 02:32:26 PM »
No...you may need to use OCS API or for records insert just do via sql directly.
Offline WDev
« Reply #2 on: April 26, 2017, 03:02:20 PM »
At least is it possible to use a JDBC Data Access Point through JAVA SDK ?
« Reply #3 on: April 26, 2017, 07:38:15 PM »
You could read its properties yes. But is just that.
If you wanna use a DBServer you need to act as a client of it...as far as I know there is no documentation for that level
Offline RobertH
« Reply #4 on: April 27, 2017, 06:22:33 AM »
Easiest way tu insert new records into calling lists is direct sql, the campaign associated with that list must be unloaded. If you want to update records at ocs operation, then you have to use ocs api. Ocs is caching loaded records from db.
Odoslané z D5803 pomocou Tapatalku
