Author Topic: import callinglist  (Read 4066 times)
Ton Koenders
import callinglist
Is there a simple way to import let's say an Excel file with only Contact names and phonenumbers, into the calling list of Genesys Outbound 6.5 (with all its mandatory fields) ?
Superglide
import callinglist
  • You could save the spreadsheet as an ascii file and then import it.
    Paulo
    import callinglist
  • Hi folks,
    does anybody know a way to automate the callinglist importing?
    I have campaigns that I have to import more than 12 callinglists daily. It's realy a boring and mechanic task.
    Thank you all for the great help and tips.
    ecki
    import callinglist
  • Hi,
    Yes, there is realy one way to solve it.
    You have to write database script for importing your data directly to calling list tables. If you adhere the mandatory fields, you will be successful. I have made such script and it works.
    bye.
    mark newcomb
    import callinglist
  • Scripts is an easy way of automating the loading, alternatively a tool such as DataStage can be used we've found this to be our first choice as we can don't have to worry too much about the format the list is supplied to our system in. Datastage then converts it to the correct list format.
    Paulo
    import callinglist
  • Hei Ecki,
    would you mind if I asked you to send me some examples of the scripts you wrote?
    I'd like to try them at my site.
