Author Topic: ASR/TTS configuration from App  (Read 2023 times)
Offline vtpeco
« on: April 04, 2017, 11:55:47 AM »
Is there a way to specify the Speech Resource URI from within an application (vrm.client.resource.uri)?
I have multiple ASR/TTS engines I would like to access and want to change the URI from within the application so I don't have to reconfigure GVP each time.
Thanks, Val.
Re: ASR/TTS configuration from App
« Reply #1 on: April 04, 2017, 12:16:26 PM »
No, the request is sent to the ASR TTS resources, then you select language and that is it.
The URI is also used to know if the resource is alive or not so that wouldn't be possible with the method you indicate.
