" /> [SOLVED] Use of MediaEmailCreateNewOutboundEmail - Genesys CTI User Forum
Author Topic: [SOLVED] Use of MediaEmailCreateNewOutboundEmail  (Read 4170 times)
Offline petitspirou
« on: March 14, 2017, 09:38:04 AM »
I want to create a new outbound email programmatically
The same action that WDE does when a user clic on the 'mail' icon after typing an email adress
For a call, I use MediaVoiceMakeCall command and it is working well
For email, I try to use MediaEmailCreateNewOutboundEmail command but I fail to find correct parameters
The following code leads to an error "Invalid adress (NULL)":
destinataire = "test@test.com";
IAgent agent = container.Resolve<IAgent>();
IDictionary<string, object> parameters = new Dictionary<string, object>();
parameters.Add("CommandParameter", agent.FirstMediaEmail);
parameters.Add("InitialEmail", destinataire); commandManager.GetChainOfCommandByName("MediaEmailCreateNewOutboundEmail").Execute(parameters);
Can you help me to set the correct parameters?
« Last Edit: April 06, 2017, 06:13:06 PM by petitspirou »
Re: Use of MediaEmailCreateNewOutboundEmail
« Reply #1 on: March 14, 2017, 09:43:38 AM »
What about From Address?
Offline petitspirou
« Reply #2 on: March 14, 2017, 10:05:08 AM »
Normally, it is not mandatory to specify it in the outbound creation, the agent will select it during redaction
The API is really not clear...
Chain MediaEmailCreateNewOutboundEmail
-IsPossibleToCreate
---CommandParameter: IInteractionInboundEmail
-AddSignatureParameters
---CommandParameter: IMediaOpenMedia
-AddResponseSignatureParameters
---SignatureOptionValue: String
---ESDKInboundEmail: Interaction
---ThreadingOpenMedia
---ParentInteractionId: String
-Create
---InitialEmail: String
---UserData: KeyValueCollection
---Extensions: KeyValueCollection
---SignatureParameters: Dictionary<string, object>
-AddRecentCall
---RecentIndex: ObjectTC
Offline petitspirou
« Reply #3 on: March 14, 2017, 02:02:59 PM »
Found
InitialEmail is not the good parameter
I had to add the userdata "To"
Weird API
Offline petitspirou
« Reply #4 on: March 29, 2017, 01:54:19 PM »
Another question
What parameter control the initial content of an email using MediaEmailCreateNewOutboundEmail?
Offline petitspirou
« Reply #5 on: April 03, 2017, 10:40:02 AM »
any idea?
It is amazing that the API do not expose such a parameter
« Reply #6 on: April 03, 2017, 12:20:30 PM »
What is initial content?
Offline petitspirou
« Reply #7 on: April 04, 2017, 09:22:40 AM »
Subject and Body
Here is the scenario:
- Agent works on his CRM
- In a use case, he clicks on a "create email" button with parameters (email address, subject, message of the email)
- WDE must open a new outbound email window with subject and body already initialized
I tried to fill the param "InitialEmail" but it did nothing
Here is the code of the email creation:
                    KeyValueCollection kvc = new KeyValueCollection();
                    kvc.Add("To", destinataire);
                    kvc.Add("Target", destinataire);
                    kvc.Add("Target Type", "TypeDestination");
                    parameters.Add("UserData", kvc);
A new outbound email window is created with correct "To"
Offline petitspirou
« Reply #8 on: April 06, 2017, 06:12:47 PM »
Found the problem
I use agent signature and this override the email content I give to the MediaEmailCreateNewOutboundEmail command
Apparently, it is a "replace" function and not an "add" one....
keys used are:
"Subject", "StructuredText" and "FromAddress"
