Author Topic: IWS menu customization  (Read 2533 times)
Offline yves
« on: March 06, 2017, 01:26:29 PM »
I'd like to customize the button showing Username with colored StatusIcon which after click executes dropdown menu with possible UserStatuses.
Unfortunately I don't know, what's the name of the View and parent region, so I have no chance to customize...
Can You help me?
Offline RobertH
Re: IWS menu customization
« Reply #1 on: March 11, 2017, 06:58:40 PM »
Im afraid, you will not be able to change it. It is better to try to hide it. It is worth to try to hide it and create your own view.
Odoslané z D5803 pomocou Tapatalku
Offline yves
« Reply #2 on: March 16, 2017, 01:32:08 PM »
And how can I hide it?
Offline RobertH
« Reply #3 on: April 24, 2017, 08:17:48 PM »
Sorry I was busy. Did you found the way how to do it?
Offline yves
« Reply #4 on: May 22, 2017, 11:47:20 AM »
Not yet.
