Author Topic: After Call Work  (Read 5150 times)
Eva
After Call Work
Hello @ll,
we need to report the after call work time.
We have Genesys 6.5, a Nortel Meridian with Symposium 4.2 as Link.
Does anybody have a solution how to report this value?
Because it is not a standard feature like a Alcatel switch provice.
Eva
joe
After Call Work
Is not the TotalAfterCallWorkStatusTime statistic doing this ?
Gandalf
After Call Work
In order to achieve ACW with Meridian 1 switch the following component versions are required.
SWITCH:
The Meridian 1 switch doesn't offer any kind of ACW or WrapUp, but release 22 of the Meridian 1 switch introduced 'nocalldisconnect' feature.
The 'nocalldisconnect' feature allow the Meridian 1 switch to place an agent in a not ready state after the release of a call.
By design, the agent would always go to a ready state after every call. To use this functionality, there must be a 'RequestAgentNotReady' send
to the Meridian 1 switch while the agent is active on a call.
The Meridian 1 switch will send the 'Not Ready Response' back immediately, but the 'EventAgentNotReady' will not be sent until the
active call is released.
TSERVER:
The 'nocalldisconnect' option was introduced in version 5.1.580 of TServer for Meridian 1 switch.
This option specifies the way the Meridian 1 switch will handle calls if the workmode parameter is set to AgentNoCallDisconnect in the TAgentSetNotReady feature request.
STAT SERVER:
Starting with version 6.5.101.06 the Stat Server supports the ACW implementation made in TServer for Meridian 1 switch.
A new configuration option, 'EmulateACWForMLink, was implemented in Stat Server to support this new functionality.
Marked as best answer by on September 18, 2024, 08:17:19 AM
Eva
After Call Work
  • Undo Best Answer
  • Thanks for this information.
    We manage to enable the ACW status and can report the general ACW time. However, when we try to use a filter to report ACW time with a reason code we don´t get any value neither in CCPulse nor in DMA.
    STATSERVER Log
    Server: [07/29/03 10:05:59] Switch 'Switch', 'EventAgentNotReady'
    ThisDN '643005'
    Agent LoginID '1002'
    This Queue '5051'
    CustomerID 'Resources'
    WorkMode 'AgentAfterCallWork'
    Reasons
    'phone' 'shtest'
    Gandalf
    After Call Work
    This functionality is planned for Genesys 7.x, but no commitments have been made as of yet.
    SWITCH:
    The Symposium ReasonCodes require Symposium v4.2 and Meridian Switch v25.40.
