Author Topic: ETL error  (Read 2861 times)
ETL error
Help, I am having a problem with ETL it is refusing to transform the data. The log says that it has trouble transforming from char to datetime format... Could it be localization settings on the machine? What do I need to change in my SQL Server?
Here is the error:
03/07/24 17:34:43.011 JST 2293760 main@6589979 INFO TRANSFORM started
03/07/24 17:34:43.402 JST 3387392 main@6589979 EXCEPT Unhandled exception happend. Exiting ...[ExcptMsg: The conversion of a char data type to a datetime data type resulted in an outof ange datetime value. Severity 16, State 3, Procedure 'IMAI null', Line 1]
Add info:
SQLState: 01000
Message: The conversion of a char data type to a datetime data type resulted in an outof ange datetime value. Severity 16, State 3, Procedure 'IMAI null', Line 1
Vendor: 242
Stack Trace:
java.sql.SQLException: The conversion of a char data type to a datetime data type resulted in an outof ange datetime value. Severity 16, State 3, Procedure 'IMAI null', Line 1
at weblogic.jdbcbase.mssqlserver4.TdsStatement.processWarning(TdsStatement.java:1207)
at weblogic.jdbcbase.mssqlserver4.TdsStatement.parseMsWarning(TdsStatement.java:1129)
at weblogic.jdbcbase.mssqlserver4.TdsStatement.getMoreResults(TdsStatement.java:812)
at weblogic.jdbcbase.mssqlserver4.TdsStatement.execute(TdsStatement.java:211)
at weblogic.jdbcbase.mssqlserver4.TdsStatement.executeQuery(TdsStatement.java:51)
at WatchDog.perform(WatchDog.java:69)
at Transformer.start(Transformer.java:241)
at Transformer.main(Transformer.java:547)
03/07/24 17:34:43.402 JST 3387392 main@6589979 END Log closed
T
Kent
ETL error
  • You would by chance happen to use SQL 7.0? We had a similar problem around one year ago and we solved it by upgrading to SQL2000. It seems like there is some sort of bug in SQL 7.0 that does not properly process dates when environment is other than USENGLISH. Try it and see.
