Author Topic: Routing points  (Read 4361 times)
Zygis
Routing points
Question:
We are using 5 RP for call routing, I created DN group and add this 5 RP, then I am getting statistic about entered call, I got more calls "Entered", What I have to do that entered call will be calcutaled only one time from firts RP?
Example:
The calls first is routed to first RP, if from this RP the calls was not answered, it is routed to another RP and waiting for available agent, and in results I will get:
Entered=2
Answered=1;
Thanks.
Marked as best answer by on September 15, 2024, 04:38:58 PM
John Doe
Routing points
  • Undo Best Answer
  • When you set up the Stats in DMA make sure the DCID box is ticked so calls are only counted once.
    John Doe
    Routing points
    Sorry I misunderstood your question so please ignore my last post. Why not just have the original RP in the DN Group?
    Routing points
    Good question!
    I was thinking about it a few weeks back, and thought of the following ways of getting it:
    1. using virtual queues to track number of calls.
    2. using filters (ThisQueue)
    3. using dequeue command to ensure that call is not queued in more than one queue at a time
    Are you using CCP or CCA?
    Zygis
    Routing points
    Yes, I'm using CCpulse and CCA.
    I was trying it, but I set VQ in first RP with name VQ_CC, and on second RP I set Virtual quueu with the same name VQ_CC, but in results I get the same results, Enterd=2, Answered=1. I tryed formula DCID, but it not working.
    I'll try it.
    I don't undestand this, How I have to do it?
    Thanks.
