Author Topic: SOLVED: Changing treatment or call result programatically in WDE  (Read 2986 times)
Offline Gabi
I've been having some trouble with this.
I need a way to set the treatment and/or call result of an outbound record programatically in a setting where disposition codes are not shown to the user.
For instance, I could treat a certain record as busy or wrong number if certain conditions are met.
Is there any way to do this?
I tried setting the call result of the outbound record both before and after the SetCallResultOutboundRecord command of the SetCallResultOutboundRecord chain, but that has no effect on the calling list.
I will appreciate any help you can provide.
« Last Edit: January 23, 2017, 04:41:28 PM by Gabi »
Offline Gabi
« Reply #1 on: January 18, 2017, 05:33:11 PM »
I found a way to do it, but then the call result I set is overwritten. This is what I've done so far.
This assumes I have an InteractionPullPreview called interaction, and that I have the result I want in a variable named result, and an IObjectContainer named container.
[code]                IInteractionPullPreview previewInteraction = interaction as IInteractionPullPreview;
                IRecord outboundRecord = previewInteraction.OutboundRecord;
                outboundRecord.CallResult = result;
                outboundRecord.SystemFields["GSW_TREATMENT"] = (object)"RecordTreatCampaign";//Or "RecordTreatPersonal", depending on your needs.
                IEnterpriseServiceProvider. enterpriseServiceProvider = container.Resolve<IAgent>().EntrepriseService;
                IOutboundService oService = enterpriseServiceProvider.Resolve<IOutboundService>("outboundService");
                IDevice device = interaction.Agent.FirstMediaVoice.Device;
                oService.UpdateRecord(device, outboundRecord, null, null);[/code]
But then the MarkProcessedOutboundChain command overwrites the call result. :(
« Last Edit: January 19, 2017, 02:10:02 PM by Gabi »
Offline PeteHoyle
Re: Changing treatment or call result programatically in WDE
« Reply #2 on: January 20, 2017, 01:06:34 PM »
Try this code snippet, it will update the call result in the model, but not the view, but it should be enough.
            [code]
            if (!string.IsNullOrEmpty(interaction.BundleId))
                IInteractionsBundle interactionBundle = interactionManager.GetBundleById(interaction.BundleId);
                if ((interactionBundle.UserData != null) && (Application.Current != null))
                    Application.Current.Dispatcher.Invoke(new System.Action(delegate()
                        outboundDispositionViewModel = interactionBundle.UserData.TryGetValue("OutboundDispositionViewModel") as IOutboundDispositionViewModel;
                        if (outboundDispositionViewModel != null)
                            //Set the Call result, does not update the view..
                            outboundDispositionViewModel.SelectedCallResult = callResult;
                        else
                            log.Debug("outboundDispositionViewModel is null");
            }[/code]
Offline Gabi
« Reply #3 on: January 23, 2017, 04:40:56 PM »
Thank you!
