Author Topic: Reg : Not able to create operational parameters in GAX  (Read 3559 times)
Offline ashokr83
« on: December 30, 2016, 10:55:33 AM »
I have done the "GAX Installation" in our lab. But when i tried to add  "Operational Parameters" it throws "Saving Failed" error.
Below listed are the error shown in logs.
[com.genesyslab.gax.opm.entities.Parameter]; nested exception is java.beans.IntrospectionException: type mismatch between read and write methods
Please guide me to fix it.
KM
Re: Reg : Not able to create operational parameters in GAX
« Reply #1 on: January 02, 2017, 12:32:24 PM »
Did you create an OPM database?
Offline ashokr83
« Reply #2 on: January 03, 2017, 09:57:25 AM »
No,We didn't created any OPM database, instead we set the "write_json" option to true under "opm" section in configuration.
Is OPM database is mandatory? If so, please guide me to  do that installation.
KM
« Reply #3 on: January 03, 2017, 10:02:51 AM »
What tables are in your database for GAX?
Offline ashokr83
« Reply #4 on: January 03, 2017, 11:12:16 AM »
Currently below listed tables are available in GAX
db_upgrades_history
plugin_persistence
asd_deployment
asd_deployment_action
asd_ip
asd_ip_content
asd_ip_owner
asd_sd
asd_privileges
asd_default_roles
asd_default_roles_priv
arm_ar
arm_arf_orig
arm_ar_content
arm_ar_file
arm_encoded_file
arm_personality
opm_custom_value
opm_op_custom_value
opm_op_parameter
opm_parameter
opm_pg
opm_pgt
opm_pgt_app
opm_pgt_element
opm_pgt_section
opm_pg_app
opm_pg_element
opm_pg_section
sequence_table
db_schema_version
~KM
Offline ashokr83
« Reply #5 on: January 05, 2017, 07:34:21 AM »
Kubig, Is there any update please..?
« Reply #6 on: January 05, 2017, 08:05:03 PM »
? Open an eSR with Genesys if you need a response in a desired time window.
